^Truth.
I have run almost every wheel size on my G; from 15, 16, 17, 18, 19's. The ride difference is not all that noticeable if that's what you're worried about. You're not gong to rub if you do the proper research and fit the correct size wheel and tires on your ride. The most you would have to do if it hasn't been done already by the previous owner is to roll or cut the inner lip on your rear fenders. In most case's that is the main rubbing issue on our cars.
Best tire sizes for our G's on custom wheels is:
17" 225/45/17
18" 225/40/18
19" 225/35/19
20" 225/30/20
(225 is usually the best width assuming that the wheel width is at least 7.5" -8.5" wide)
That is a big freebie I just gave you there, so take that info and use it to make your purchase on a new/used set of wheels and tires. Best place to look is Craigslist for a nice set of used wheels, or ask Blue8G to help you look for some wheels...
