stroke, yes, bore no, if the bore is increase enough, a shorter stroke crank can be used, which even with the original con rods, will allow for for higher revving and because of the increased bore, there is not much displacement lost, but bottom end torque will be sacrificed because of the shorter stroker, for your build specifically, just boring out will do nicely
