NEWBIE
O2 Sensors
Hi fellas, quick question on 2 02 sensors. I got the codes of the odb and want to replace them. However, I did not know which sensor to buy based on upstream or downstream.
P0141(Bank 1, Sensor 2)- upstream or downstream?
P0155(Bank 2, Sensor 1)- upstream or downstream?
New Member
NEWBIE
Cool, so from that list, both say (heater). This means downstream right?
New Member
Yes, the heated O2 is downstream
4cly b1s2 is the p/s downstream. B2s1 is driver side upstream
V6 b1s2 is the rear exhaust manifold down stream. B2s1 is the front exhaust manifold upstream
NEWBIE
OBD reader says all o2 sensors bad
