Lulz, I missed your post, it was meant at person above you.
surplus tailights aspire
I picked up a pair of Rockford Fosgate T1 series 6x9
Purchased JDM black housed headlamps and 2nd Gen tailamps
Replaced passenger side mirror with new OEM mirror.
Got me some JDM goodies finally:
They are in great condition too:
Let the retrofit begin!! FX-R's with Osram CBI 5000K D2S bulbs. Oh the intensity!
-Greg
Changed out the valve cover gaskets and plastic rings on the spark plug tubes, also added 3 new spark plug wires to the front, due to the old one ripping out.
I also did an oil change.
This was a on sat btw, been kinda busy lol
Up next is O2 sensors
02 Galant GTZ stock
00 S10 Bagged on 20's Suicide Doors 5 link and control arms, more to come!
<-----used felpro gasket and tube seals, did it right. No leaks.
^^^ Any damage to the head?
What oil were you running?
I began open heart surgery on the YardDog
Catastrophic failure
Oil pump seized and the timing belt split the oil pump sprocket which then cut the timing belt throwing the timing
Slammed cylinder #2 into the valves breaking the connecting rod
Tore up the piston
And did this to the block
And I had a replacement head that I have all cleaned up not that it will be used on this block now
And installed a 3G steering wheel
then detailed it to end the day with a positive
Me I'm a lil of both
^^^ Its probably a setting he is using. I think it adds a catastrophic effect.
