Thread: A supersupercharger on Galant 9
Page 6 of 6 FirstFirst ... 23456
Showing results 101 to 116 of 116
  1. #101
    This past weekend engaged in the compressor. It was necessary to get rid of the pins and make possible the accession of silicone drainage 90 degrees. Retracting the metal is not possible, because there is not enough space. Now it looked like a snail compressor. At first gave a rough form.
    Turbo - it is a snail, but the bitch is very fast.
  2. #102
    Further, there should be more careful processing. In the cochlear there are three tide One of them is located in the upper part of the It also decided to cut off. The account goes on millimeters. When closing the hood, up to a snail 15 mm. Therefore, cutting this tide, added another 10 mm the gap between the compressor and the hood.
  3. #103
    Now you can compressor set. Flooded with oil in it. Use full synthetics for cat 75w140. Very good oil is recommended for rear gear Nissan GTR, this is a very serious car. Why this oil? "because the conditions of work of gears as the gearbox, the volume of oil is very little 70g. Therefore, the need to use this oil with high viscosity parameters
  4. #104
    The compressor is ready to install. However, attach the drive belt failed. You will have to install additional parasitic pulley for proper coupling belt. The other day I finish.
  5. #105
    I want to tell you how to make an additional pulley. It is necessary in order to remove the belt. First I bought a pulley. You must install the bearings.
  6. #106
    Pulley steel, made a robot, accuracy is not bad. The first thing to do, sharpening hub of steel 40H (Russian standard). The hub on a hot pressing inside the pulley. Internal diameter of the sleeve is made under the bearings. On the reverse side of the pulley cut off the bottom. Now make a yoke under timing belt. Inside the sleeve is made recessing a snap ring and Burt at the end of the sleeve.
  7. #107
    Set bearings and produced axis to a pulley.
  8. #108
    Then all set to the motor.
  9. #109
    Oh, it's noisy. A very powerful stream of air. Now I want to drive 2-3 weeks with no load. This lapping of details.www.youtube.com/watch?v=fo10-khkTrM
  10. #110
    Wow, man. I love your supercharger! That is awesome work! I hope someday I can have some type of forced induction in my 9G. You should post any news on it and how it's doing. You give me lots of hope lol.
  11. #111
    Experienced TGC Member
    03-13-2012
    Manvel Texas
    1,171
    Good work man!!!you got some skills.i want one for my 8g!!
  12. #112
    Hi stayer have u had any progress with this supercharger setup?
    Sent from my LGLS775 using Tapatalk
  13. #113
    It was 5 years ago. I made several sets and sold in Russia. Now not produced anymore.
  14. #114
    What about the turbocharger? Had any success?
  15. #115
    this is for stock injectors, pistons, etc.
    https://www.thegalantcenter.org/show...G69&highlight=
  16. #116
    Coralie
    At first i made a shaft and a pipe. Later pipe manufactured anew, changed the landing of the bearings.Later pipe manufactured anew, changed this site
 landing of the bearings. The shaft is made of 4140 steel. . Bearings japanese NSK.
Tags for this Thread
