I'd rather have stock piping with a K&N or some other cone filter than waste $200 on a CAI....
A padded shroud will not help since the battery hold down bolts will still be outside the shroud. In my instance, I relocated the battery because my Injen intake would not fit properly after my Diamante plenum swap.
^^It really is pretty much the same thing. I replaced mine only because the resonator close to the TB fell off and the tape would no longer hold up to the summer heat, but up until then I ran the stock tube and specter filter. And in the short year I had the aluminum eBay pipe it had already started to show wear from the battery.
Not like any real gains will be mad either way, why not just stick with something that will always fit like OEM?
So why not stick with the OEM airbox as well?
OEM is not always better. Take it from someone who works on OEM shit all day everyday. Some of these designs these engineers get paid six-figures for are total garbage. Like they've done a hallucinogen right before they hit the drawing board. OEM is NOT always better.
The "accordian" part of the stock 8G intake alone creates turbulence in the air flow through the intake that it actually decreases airflow going into the throttle body.
I used to think the whole $200 intake was garbage as well but I've seen it enough times to see theres actual advantages to a legit straight through intake than just slapping a cone filter on the stock intake.
Jigz, I know that OEM is not always better, they have to do things that may just be 'fine' in order to achieve other goals that are deemed more important.
I'm just saying for the little gains to be had I couldn't justify the $200.
And I would just leave the intake box haha
this is old but.. my solution is just to get a smaller battery
looks good
Nice color scheme under the hood
The color looks gd bro
GWAP STACKIN MAKE'S IT HAPPEN
Really late update:
The 5-speed swap was alright, it was a PITA at times (like changing out the shifter cables) but it was also my first time doing something like this. I think it might've been easier if I pulled the engine with the transmission out and just swapped the transmissions outside the car.
Here's some pics from the swap:
So when I was doing the swap my cousin happened to buy 9g in red lol!
The axles, hubs, and knuckles
The auto transmission out
The auto starter plate off
Flywheel on
Exedy clutch on
Manual transmission ready to go on
All done!
It was supposed to be lowered yesterday but something came up, so hopefully I can go low this upcoming weekend.
Okay so I've been thinking about my exhaust setup & wanted to get some opinions. I want to do RPW long tube headers with the eBay piping that comes with the eBay exhaust (since I've read it's not that bad) and a Greddy SP2 muffler. Is this alright or should I do something different?
nice work! looks like youve got a nice shop to work on it in. lots of room!! cars coming along great, keep up the good work!
its a heck of a lot better than doing it on your back in the street on a 30 degree day!
Never heard an actual greddy, but Tsudo makes a replica that I thought sounded nice. If it sounded good on a 4cyl, I imagine it would sound even better on our v6's. You can find em on ebay or the retailer of your choice..just type tsudo sp2
http://m.youtube.com/#/watch?v=bZ3g2...%3DbZ3g2Eg3Qu0
