good idea
What do you guys think of this?
http://www.ebay.com/itm/UNIVERSAL-90...ht_2845wt_1163
Or just go with stock
http://www.ebay.com/itm/mitsubishi-o...#ht_500wt_1413
Also found this
http://www.ebay.com/itm/99-00-01-02-...#ht_2540wt_988
And stock v6
http://www.ebay.com/itm/Mitsubishi-E...ht_1303wt_1163
What do you guys recommend?
I personally recommend the V6 or outlander, that eBay one is probably more of a headache than what it's worth.
Go with the V6 TB. They're easy to find... And install. Just make sure you get the right gasket and bypass the coolant lines.
I'll PM you in a bit about the shifter
Sent from my SAMSUNG-SGH-I777 using Tapatalk
-Andrew
Pretty clean. Fix up that rear end and your golden.
Well since no one would answer this question when it was a topic on another thread anyway that kept getting ignored and posted over....Let's try here
Everyone who was saying to cut my grill and put mesh behind it, how would I go about doing that?
i would start with a saw or dremel and some mesh.
http://www.customcargrills.com/products.asp?cat=27
And a little cheaper on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_1795wt_1396
yea looks good depends on your taste i guess. i would bend it around the grille and glue it with some epoxy or somthing
I was thinking that and on the website they have like rubber frames that goes around it to taper off the sharp edges
who cares about sharp edges its going to be glued back and you will never have to touch it hopefully.
yea i was going to say something about that but ive never used it before so i couldnt tell you anything about the quality..
Hmm I'll look into that I'm getting my remote starter fixed now so I'll head over there afterwards
