Thread: MKO's AWD/Turbo/DOHC/5 Speed Project
Page 36 of 53 FirstFirst ... 2632333435363738394046 ... LastLast
Showing results 701 to 720 of 1043
  1. #701
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    JUst did a compression test for the first time after the engine was rebuild year and a half ago. Now that it has 2g head instead of Hyundai head it dropped 20 psi a cylinder. Either way, its holding 200psi across the board.
    Quote Originally Posted by wetamup2k3g View Post
    Badass that you had the mishap and got it back up in no time!
    yeah bro, i was workin my ass off on this one. If it wasnt for the finding valve spring compressor and cleaning the head delays, I would have done it in a day. But Im happy shes running again.
    Build Thread
  2. #702
    08-13-2008
    Waterbury, CT
    3,331
    visionary, 7gs have an F5M31 5 speed and the 2g GSTs have an F5M33, longer and stronger gears is the difference but the 31 is fine.
    MKO, looking really good man.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  3. #703
    09-20-2007
    Sea Isle city, NJ
    4,098
    Look at this Addco sway bar fitting the AWD subframe......man Im so excited,,,,its got no clearance issues. It definitely fits better that it does on the FWD subframe.
    Finally back on all four. Its been long three months.
    Bunch of Subbies and DSMs in the yard.
    And of course there's always a problem. It looks like my rear coilover shock is leaking.
    and some funnies... I found this 420A talon in the junk yard. Someone has tried to fit a flipped Mirage motor in it. I was ROLFing when I saw it. lol
    Build Thread
  4. #704
    i see a GVR4
  5. #705
    That's the one I want then and
    Dayum mko you got a car lot
    Me I'm a lil of both
  6. #706
    12-17-2004
    Louisville, KY
    4,327
    Looks good. I pulled all of my carpet and installed household 3/8" foam carpet pad. Helped to quiet road and exhaust noise dramatically. Not to mention its cheap and fairly lightweight. The factory carpet went right back into place as if I didn't change a thing.
    That outback looks identical to mine. Mines a 2.2 5 speed with the leather interior.
    Subaru makes great cars. Very easy to work on.
  7. #707
    09-20-2007
    Sea Isle city, NJ
    4,098
    Started working on the front end. Dont have recent pics, but 80% of it is finished.
    Build Thread
  8. #708
    09-20-2007
    Sea Isle city, NJ
    4,098
    Engine bay is finally finished. Im waiting on a few parts to come in so I can put it all together.
    Build Thread
  9. #709
    09-20-2007
    Sea Isle city, NJ
    4,098
    Got the driveshaft back from the shop and it looks very nice. It totaled $175 for shorting the front piece and replacing the middle piece tube. As I was leaving my starter got weird and I couldnt start the car. I got one from advanced auto for $70 and I hope it holds up.
    Build Thread
  10. #710
    Did you pop start it or something to get it started?What was it doing just cranking really slow?Maybe the ground for it got loose or something.
  11. #711
    09-20-2007
    Sea Isle city, NJ
    4,098
    At first It dragged and I thought my battery died so I went and bought new battery. When that didnt fix the problem, I was like let me tab on the starter and then it did nothing when i tried to start it. Luckily my friend got there and we did a bumper to bumper push and I roll started the engine so I can get home. yeah it was fun.
    Build Thread
  12. #712
    09-20-2007
    Sea Isle city, NJ
    4,098
    Im doing all harnesses with braided loom.
    Build Thread
  13. #713
    how thick is your rear swaybar?
    project is comin along nicely mate
  14. #714
    09-20-2007
    Sea Isle city, NJ
    4,098
    I cant mount the driveshaft for some reason.....upsetting
    Quote Originally Posted by unclepaulie View Post
    Its 22mm Addco sway bar.
    Build Thread
  15. #715
    Why cant you mount the driveshaft?It wont line up or something now
  16. #716
    08-18-2004
    Charlotte, NC
    1,029
    Looks like they were testing the engine to see if it would swapable. They could have use the newer 4G64 if that what they were after.
    1994 GS FYI
    DSM/CSM Manuals
  17. #717
    ahh ok, thatd should be fine. if we (vr4 guys in aust) use 27mm bars on the rear, then the rear mount on the arm is usually reinforced. a few guys have torn the mounts from the control arm. 22mm should be ok
  18. #718
    09-20-2007
    Sea Isle city, NJ
    4,098
    So I'm reviving the thread. I got lots of new parts and im going after horse power this summer, enough is enough with exterior and interior mods.
    I need to get tatrix 2.0 cable now.
    Build Thread
  19. #719
    09-20-2007
    Sea Isle city, NJ
    4,098
    Last parts just came in.
    14'' fan, Aeromotive rail with 750cc injectors, Fidanza flywheel and pressure playe and ACT clutch disc, 290 lbh Supra pump, and the last axle i need.
    Build Thread
  20. #720
    U r welcome to come by and use my tactrix 2.0
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
