The light is unique to the svr4 wing dude,I offer the replica wings ,it seems silly to spend hundreds if not over a thousand on molding fabricating and redesigning the wheel when it already exists so just buy a genuine 1 or a glass replica
LOL! This is one of my original ideas...my fabricator has an eye for duplicating stuff just by looking at pictures...though of course not 100% in which I really don'y mind.
However, the wing might be an exception. I'll most probably buy a replica one in the end if the cost of fabricating one will be higher than the replica![]()
www.qcustoms.co.nz
QUESTION!
Is the SVR4 Red Carpet similar to the fabric of the RECARO RED fabric seat?
SVR4 Carpet
I was able to score the SVR4 4 door panels with the covers. Lucky me
Actual pic of the items
I want to save on shipping so I'm planing to remove the small SVR4 4 Panel covers and leave the big pieces behind.
Picture taken from the net.
I noticed though that the big pieces are not the same color as my VR4's...mine's Bluish gray.
Should I leave them attached to the bigger piece and have them shipped all together? Or have the little ones detached just to save on shipping?
I don't know if the actual bigger pieces came from an actual SVR4. The previous owner told me that he also got them that way.
For clarification...what are the small little ones it t SVR4 pattern called?
What's the bigger part of the door called wherein the smaller ones are attached to?![]()
Formerly 386 kms. apart...
My 8g and I are now together...FOR-E-Vah!!!
It's door card inserts ,the fabric is called an insert.
Now you can remove and fit the new inserts by simply melting the rear knobs and cleaning them and then pushing the new inserts in and melting the ends once pressed in.. Iv done it but it's not easy and be carefully not to break the door cards whilst the inserts are out tho
www.qcustoms.co.nz
You'll never learn anything if you don't try man.. It's easy. Practice makes perfect. You'll get good with hands on work man...
www.qcustoms.co.nz
I'll practice...but not on these babies LOL!
And the person that will do the cutting is not me but my friend, the door card inserts with the door panels are with him now abroad and he won't touch them that would cause damage to it.
Speaking of SVR4 parts, I'll be e-mailing you in a few mintues![]()
