Thread: 2.4L 02 Galant ROM and XML flash *progress*
Page 6 of 6 FirstFirst ... 23456
Showing results 101 to 118 of 118
  1. #101
    08-18-2004
    Charlotte, NC
    1,029
    I wonder why the late model NA ecus have a 100% load limit. Some early ecu like the RVR I'm using have a max load of 120% but the GS ecu has 100%. While the MAP sensor only ECU, like the mirage 1.5L, has 160%
    1994 GS FYI
    DSM/CSM Manuals
  2. #102
    TGC Regular bgood12's Avatar
    07-17-2009
    From Dallas, Texas in Topeka KS
    554
    Its the car industry man, they prob were ablt to the ecus on more back in the day and maybe had to change a chip or two to load vehicle specific info. Lately since the only thing they turbo sare the evos and maybe diesel trucks it didn't make sense to use a boost capsable ecu prob so they went to standard ecu for all cars that can swapped and unique ecu for boost.
    Sent from my BlackBerry 9360 using Tapatalk
  3. #103
    06-13-2008
    Bronx, NY
    2,606
    ^ Yes. our car 99-03 Galant. 00-05 eclipse they all are naturally inspired. Meaning you wont see loads above 100 loads due to mechanical spec. So all PCM or ECU are code to read loads only to 100, it wont read above 100 loads boost levels. The evos, 3000gt, 2g eclipse turbo, have the code to read the loads above 100 loads making the ecu capable for boost. New fuel injected cars works around the same concept.
    SOHC Turbo
  4. #104
    thank you i will get the cable when i have money and do that.
    how much do they run?
  5. #105
    07-17-2009
    554
    O wanna say 160
  6. #106
    ^^^ really!
  7. #107
    07-17-2009
    554
    Its easy to find go to tactrix.com and a few clicks and it should show up that's hella cheap for what it can do
  8. #108
    You don't say I'll have to check that out!
  9. #109
    Quote Originally Posted by bgood12 View Post
    O wanna say 160
    200 with reflash cable and shipping
  10. #110
    06-13-2008
    Bronx, NY
    2,606
    Best tool you could used.
    SOHC Turbo
  11. #111
    TGC Regular djhah's Avatar
    03-15-2010
    nashville, tn
    505
    Sucks our ecu wont read boost :/ unless it has been worked out?
  12. #112
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by djhah View Post
    It could read boost but dont have the resolution to tune above 100 loads and above 100 load pcm guess the timing u dont hade control and it could damage the engine. Is a member using stock pcm and he is boost and he is making good numbers. Is not recommended to do it if you dont know what u doing. This member knows what his doing thats why is going well for him.
    SOHC Turbo
  13. #113
    *raises hand*
    You have to be reeeeeeally careful tuning in this situation and understand how the ecu interpolates to make it choose the timing you want to run. I definitely cant wait for big maps though. Its going to change power goals for future builds for sure!
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  14. #114
    03-15-2010
    nashville, tn
    505
    Good to know
  15. #115
    Hello! Do you have XML for galant 8 2.4 2000 512kb ? please send [email protected] . Thank you.
  16. #116
    Quote Originally Posted by ToreroSK View Post
    Did you not notice how old this post is?
    Sent from my LM-G710 using Tapatalk
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  17. #117
    I know the old post. I did not create a new post, so as not to create unnecessary topics, I wrote here, the post will rise and people will see, send XML. I hope))
  18. #118
    No one is sending anything. If u asked then you would have found out that the author of this post is not around anymore.
    '95 Kawasaki ZX9R
