I think if the spacer is hub centric, then I believe you could use hub centric rings between the wheel and the spacer. Just my opinion though.
http://www.ebay.com/itm/2-5mm-Hubcen...ht_2858wt_1139
yay!
Are you going to get longer studs as well? I believe you have the same size RPF1s as I do and I don't think the studs would be long enough after putting on spacers.
