TGC Regular
8gen Parts List - 3/2004
This is due to the amazing lack of the search feature here on TGC. A current list that will grow in time but will give the newbies a one stop spot to see where to put there money for what kind of gains. I believe only moderators will be able to edit this list so if there is something to add or an opinion seek one out.
Adjustable Cam Gears
Aem: Great quality, can never go wrong with AEM
Aluminum flywheels http://www.aluminumflywheels.com/cam_gears.html
Cold Air Intake
Injen: Poor quality, 2 inch hole wore into nto it from rubbing against the battery support post.
Weapon-R: Gave them respect for having a CAI back when the 8g was first introduced. Lost all respect when noticed it was poorly designed, I 2 inch hole wore into it from rubbing against the battery support post. Poor Customer support (if any)
ECU upgrades
Jet chip: Should be absolute last mod you do. Expect down time! Worth the investment.
Venon 400: Shifts the powerband does not give the 25% increase of hp or torque. Defintely not worth the $325 price tag
Exhaust Modifications
RPW headers jet: Proven to be not worth the money invested
Fuel Pressure Regulator
Obx: Average price, comes with a gauge to adjust the pressure, good quality.
Motor Mounts
Deyeme Racing: Refer to 2001-2003 Stratus/Sebring Coupe listing. Do yourself a favor order the complete set of 4 for 269.00 They replace your OEM mounts unlike other vendors. Beaware they do not respond to emails, phone calls nor smoke signals but they do great work. http://www.deyemeracing.com/products.asp
Pulley Kits
Aem: http://aempower.com/
(I4) +1 or +2 whp , only noticable on a dyno. $125.00 Alt and waterpump pulley
(v6) $85.00
ASP: http://www.aspracing.com/
crank pulley http://www.aspracing.com/
OBX: http://www.obxracingsports.com/
(i4) alt and power steering pulley
To have something added or to give stats on a item message me or another moderator to have it added.
Added from Clone2020:
FIND A DEALER
- http://www.mitsubishicars.com/retailers/index.html
SERVICE MANUALS
- http://www.helminc.com/helm/search_service...=&class%5F2=MIT (99=$90; 00=$135; 01&02&03=$180)
MUT-III (Multi-Use Tester)
- http://www.spxotc.com/ (rent=586-578-7289; buy=800-533-5338)
BODY KITS
- http://www.andysautosport.com/mitsubishi/9...galantkits.html ($863)
CHROME BLINKER BULBS
- PEPBOYS, SCHUCKS, AUTOZONE ($7-$15)
- http://www.andysautosport.com/mitsubishi/9...loredbulbs.html ($15)
HEADERS (I4)
- http://www.ptuning.com (Starting @ $250 + 5% Discount code = ptgalantctr)
HOODS
- http://www.andysautosport.com/mitsubishi/9...alanthoods.html (Starting @ $329)
INTAKES
- http://www.ptuning.com (Starting @ $165 + 5% Discount code = ptgalantctr)
INTAKE COUPLERS/CUFFS
- email Josh @ "[email protected]" (blue/yellow/red = $5 each)
FLOOR MATS (Diamond Plated)
- http://www.evolution-autodesign.com ($155)
LEATHER
- http://www.nwautoleather.com/nwautoleather...mitsubishi.html
- http://www.katzkin.com/ (Starting @ $679)
OEM PARTS
- http://www.professionalautoparts.com/ (888-231-5287)
- http://www.mitsubishi-parts-wholesale.com/ (800-279-6698)
- http://www.mitsubishipartstore.com/ (800-267-1844)
- http://www.overnightautoparts.com/mitsubishi.html (888-267-1845)
- http://www.pitstopautoparts.com/oem-mitsub...ishi-parts.html (800-814-8772)
- http://www.mitsubishiparts.net/ (866-754-5500)
- http://www.drivewire.com (949-387-1900)
OXYGEN SENSORS
- http://www.oxygensensorwholesale.com/mitsu...999_galant.html (Starting @ $65)
- http://www.professionalautoparts.com/mi_19...225-1300_6.html (I4 Starting @ $92)
ROTORS & PADS
- http://www.raceconcepts.net (Ask for "TGC" Discount)
- http://www.ptuning.com (5% Discount code = ptgalantctr)
SPARK PLUG WIRES (Magnecor KV85 8.5mm)
- http://www.magnecor.com/magnecor1/files/catalog.pdf (MAGNECOR's Price List)
- http://www.magnecor.com (I4 = Part # 45182 = Retail $96.75)
- http://www.magnecor.com (V6 = Part # 65233 = Retail $337.75)
- http://www.ptuning.com (I4 = $69 + Shipping +5% Discount code = ptgalantctr)
- http://www.empowermotors.com (I4 = $70 & V6=$130)
- http://www.lightningmotorsports.com/magnecor.htm (I4 = $67.73)
- http://www.alamomotorsports.com/mag_mitsubishi.html (I4 = $65)
SPARK PLUG WIRES (NGK) - PART# ME96 or # F1020-108641
- http://www.ngk.com or http://www.sparkplugs.com (I4 = $22.15)
- http://www.professionalautoparts.com/mi_19...253-1604_6.html (I4=$30)
- http://www.autopartsworld.com/1999_mitsubi...-set_parts.html (I4 NGKs = $26)
- http://www.importrp.com/mitsubishi_wires.htm (I4 NGKs=$20.62)
COIL PACKS (for the I4)
- http://www.partsamerica.com/PartDetails.as...ype=190&PTSet=C ($105.99)
- http://www.partsamerica.com/PartDetails.as...ype=190&PTSet=C ($183.99)
SPRINGS (Progress)
- http://www.ptuning.com ($170 + 5% Discount code = ptgalantctr)
STICKERS
- http://www.vinylworkz.com/
- http://www.ap-signworks.com/motorsport/rollcall.asp (Roll Calls = $40)
- http://www.ap-signworks.com/motorsport/race.asp (Race Numbers)
STRUT BARS
- http://www.ptuning.com ($90 + 5% Discount code = ptgalantctr)
SUPERCHARGERS
- http://www.rippmods.com (V6=$3849.95)
TAIL LIGHTS (EURO/ALTEZZA STYLE)
- http://www.andysautosport.com/mitsubishi/9...taillights.html ($250)
- http://www.slickcar.com/productdetails.asp...?ProductID=2771 ($180)
TIE RODS
- http://www.overnightautoparts.com/mitsubis...04-tie-rod.html
TIMING BELT
- http://www.professionalautoparts.com/mi_19...552-1039_6.html (I4=$53)
- http://www.autopartsworld.com/1999_mitsubi...belt_parts.html (I4 = $49)
WATER PUMP
- http://www.professionalautoparts.com/mi_19...W361-965_6.html (I4=$150)
