Is the 3g radiator same as the 8g? My 3g rad has only one fan in the middle instead of the 2 my g has.
For anyone that is upgrading to the 6g74 throttle body and need the IAC pigtail, you can order one from http://www.msrecycling.com/mitsubishi/diamante.htm I've been looking for one for several months now and I finally found one. Hope this helps someone else.
01 Galant ES V6 MT (sold)
00 Eclipse RS MT
4g64T 5spd
Iirc the height is different on both. One is shorter than the other but can't remember which.
'91 Kawasaki ZX7 (SOLD)
'95 Kawasaki ZX9R
how clean would I have to get the mating surfaces of the cylinder head and the engine block for changing the head gasket?
this is as clean as I can, is it enough?
I also should point out, this isn't from a blown head gasket, so no need to deck the head, this is because a fucking washer fell in the #6 cylinder, and due to school (before summer) and work, I have just been pulling apart the engine slowly
It's recommend the head gets sent to a machine shop to resurface it for the best seal.
whats the best way to clean the outside of a transmission? like its not filthy but i want to have a bright shiny new looking 5spd when i do the swap.... i heard simple green and a wire brush anyone know the best way??? oh and i was thinking of putting a coat of paint on it bad idea or not?
2002 5spd swapped
under construction.....
'95 Kawasaki ZX9R
4g64T 5spd
Any suggestions on protection for my g? somethin affordable, but with some quality. Please and thanks guys!
What do you mean, VIP like security protection? 6 dollars maybe 10 for some wire and a bosch relay. On your fuel pump. Hide the switch and have a hidden fuel cut switch so that if someone breaks in they can't take the car.
VIP you can have a hidded switch and cut the power to the starter. Very cheap and effective.
Sent from my phone! Using Tapatalk
i meant alarm wise, just keyless entry access and some noise if some little kids run into my car or somethin in the neighborhood, but a kill switch is somethin i should also look into. cus if someone breaks into my car ill be happy they cant take the car but i also dont want them to take anything out of it
anyone know the part number for compatible Aeromotive fuel pumps?
Look on evom, I believe a fuel pump is a fuel pump to an extent?
is it necessary to replace both lower control arms if the bushings are bad on one side? i have other cars that are priority.. but i do wanna get this galant looking and running right..
i know i know.. "just replace both conrol arms" but like i said im trying to save money.. if i can get away with just replacing all the bushings id like to just do that..
First try rock auto.com for the control arms way cheaper than most anywhere else. And secondly yes u can just replace the bushings if nothing is bent or damaged but the problem is if u use standard rubber depending on where u live u will be doing it again, secondly you could ugrade to energy suspension bushing but that might defeat save money purpose. Problem with those options is most people have to blowtorch the old stuff off or press it out etc. So might take days. So I would price all those options keeping in mind what you would need tool wise to do it yourself then decide. Good luck sir.
I mean if u keep going through tires maybe u should go energy suspension and rock auto I think are cheaper than that check junk yards too.
