I dont think so but dont quote me on it.
Does anyone know if you can put a 99 2.4 SOHC block in a 94 with DOHC?
i think there are some differences in the blocks, so i'd say no...plus the the 99 engines are inverted 180 degrees from the 94, so even if the head bolts up, the mounting points for the motor mounts might be off....just find a 94-98 galant block, whether SOHC or DOHC (94 only)
How did you get your hands on a 1994 galant dohc head first off? And the answer is no. You need an Evo or Kia head mainly to work with the 99 block. Any 94-98 block will work with the head. Go to the tutorial section and look up the head swap for how to make a single came block accept the dohc head.
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
my bad, i read it wrong, if u have a 99, do what Galanttuner10 said
2014 Lancer Evo GSR
well his SN says 99...so im making an assumption
1994 GS FYI
DSM/CSM Manuals
