peel them off and then use something to get the leftover sticky residue off... i went to autozone and got stuff called "sticker shock" worked great... looks great... enjoy!
can somone please give me an idea on how to remove the pinstripes from my car.
your pin stripes were stickers?
mine are painted on.
<div class='quotetop'>QUOTE(TexasMade)</div><div class='quotemain'>your pin stripes were stickers?
mine are painted on.</div>
O_O;
Dang...
Mine peeled right off.
park the car in the sun for a few hours. it should make things better. then i just took my finger and started picking at it. you can use adhesive remover to help you out if you want.
but be careful, especially if your car is older. remember your car's paint is constantly fading and getting damaged and yea, the paint under the pin stripe is protected from the elements. in simple words, you might have a stripe of new paint under the pinstripe that might be noticeable if you don't put a new stripe.
