Thread: Baby G ~ 2000 Galant ES I4
Page 44 of 70 FirstFirst ... 3440414243444546474854 ... LastLast
Showing results 861 to 880 of 1389
  1. #861
    Experienced TGC Member xd_01's Avatar
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    car is looking sick jigz, i especialy like the time of day the pics were taken. what size tires are your running?
  2. #862
    Thanks B! They're 225/45/17. They run .5" wider than most 225/45's though.
    Jigz-TGCIL Sosick Motorsports
  3. #863
  4. #864
    You are here entirely tooo much!! IVORY_G's Avatar
    07-12-2007
    SoCal
    4,632
    Looks soooo much better!
    JDM Zenki Conversion
    Lazy hands make for poverty, but diligent hands bring wealth. (Proverbs 10:4 NIV)
  5. #865
    08-26-2007
    1,148
    i guess there isnt much room left for a 235 or 245 series, just curious cuz im looking to upgrade my wheel/tire combo 17x9 wheel also.
  6. #866
    Quote Originally Posted by xd_01 View Post
    nah, a 245 will fit on a 9" fine. I was going to run a 245/40 but I found these RE070 for $450 (retails @ $1000) with 900 miles. I couldnt pass it up. The RS-3's were around 700 for a 245/40.
    I think Martin has fit 255 on his 9" before IIRC. I'd ask him to be sure though.
  7. #867
    as for the previous page...Like a boss!
  8. #868
    08-26-2007
    1,148
    fender lip clearence was more my question, i should of been more specific. it looks like one would really need some serious fender rolling and -camber to get a 235 or even a 245 width tire in there.
  9. #869
    I run a 245/40/18 now which is a little tall with no issues. I ran a 255/40/17 before that. You only need like-1 out back and anywhere from 1.5-3 upfront in terms of camber. My fenders are all cut and the rear quarters have been welded and sealed back together. The flares will give you another 1/2 inch if space if you cut their lips as well. My 245 nt05s run wide too so it's probably closer to a 255 in all season size. I think i need to make a functional fitment thread so we.can discuss and not clutter this build thread
  10. #870
    08-26-2007
    1,148
    my bad,, back on topic
  11. #871
    the rears are rolled with a slight pull and nothing done to the fronts. Im sure with a little more pull I can get a 245 under her. only thing is that amount of pull is when the paint starts to chip and you almost have to heat it up all the way to get it not to.
  12. #872
    Got a couple of things to address this winter. Poly motor mounts, RSB, and 3". After that, nothing until the 4G64 blows up. Planning on leaving it alone next season and just tracking it.
  13. #873
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Go to the dyno!!!! Take some vids we all want to see the power. Car looks great man
    4g64T 5spd
  14. #874
    Quote Originally Posted by 4g63lover View Post
    you have 2.5" now right? sounds like a good plan!
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  15. #875
    Quote Originally Posted by OMEGA PHX View Post
    Thanks man.
    I'll save dynoing it once I get a better set-up in there. It runs awesome right now aside from running a little rich from time to time, mostly in first gear if I get too happy with the pedal all the way to the right too quickly.
    Quote Originally Posted by Ivory8g View Post
    Yep, I want a 3" mostly for sound. Going to keep the 2.5" downpipe. I was also thinking maybe fabbing up a hard pipe set-up once I relocate the battery. I'm sure it'll help with the lag and response a ton!
  16. #876
    sound and it will help reduce some of that back pressure. granted your effective diameter will still be 2.5" but it will help some. aww man and you should totally fab up a hard pipe. im thinking of learning mig and tig welding. such valuable skills with these projects.
  17. #877
    07-12-2007
    SoCal
    4,632
    I agree with OMEGA_PHX, you should dyno it just to get a baseline of where you're at now, and where you will be going later. Then you don't have to guess what you're numbers were with this setup...
  18. #878
    Quote Originally Posted by IVORY_G View Post
    I'd love to do that but thats where the money factor comes in. I can spend the money to dyno it and get numbers (im not really worried about) or spend the money to get the other odds and ends the car truly needs. I know for a fact I need to address the mounts and RSB. If I had the extra money I can strap it down and see what I make but for now, my priorities are getting the stuff the car NEEDS and in the end will keep letting me enjoy the car as a whole. you know?
  19. #879
    the nice ting about the EVO piping is the lowers are already solid piping. so I'll just have to take care of the upper.
  20. #880
    I totally agree. the lower piping is pretty solid but i always remember my upper hitting my battery and being annoying. totally not playin that game this time around.
