Thread: General 8G Question Thread
Page 17 of 33 FirstFirst ... 713141516171819202127 ... LastLast
Showing results 321 to 340 of 650
  1. #321
    Quote Originally Posted by Guzm4n View Post
    Anybody know the size of the bolts that go through the knuckle and hubs, or where to get them? I'm not even able to use my old ones cause of the rusted axles.
    Its a 12x45 part number MU140016 $3.16 from oemmitsubishiparts.com
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  2. #322
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Im trying to find a Outlander manifold, were there any 2003 Mivec Outlander's? If you know the answer just answer with a YES or NO, i know all the other necessary info.
    4g64T 5spd
  3. #323
    11-29-2009
    Chadds Ford, PA
    2,768
    I dont think so
  4. #324
    idk if this is the rite place to ask but i have a 2000 g a/t and i did a tranny swap with a 03 a/t trans but im still getting codes and it shifts rough from 1st to 2nd and speedo isnt working i put a 2000 speed sensor on it. i was wondering if you guys can help me figure out prob
  5. #325
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    for those of us that have done engine swaps, anyone know the rear lifting point for the 6g7 engines? the front point is obvious, but I can't figure out which one of the brackets on the rear head for this is
    also I have seen occasion pictures of this, is it possible to use a few super strong straps under the engine attached to the engine hoist to lift the engine?
  6. #326
    The lifting bracket in back is in the opposite corner of the front. Some engines got a tab on the steel bracket behind the upper PS bracket.
    Straps are a bad idea with the engine because the sharp ends all over it cut into them. However I have lifted all my engines with two-loop chain harness.
  7. #327
    06-18-2011
    chicago suburbs, IL
    600
    noted, although the heads are off the block right now (stripped down to the short block) and I know ahead of time the block is done (cracked), so any thoughts of hoisting the short block without putting the heads back on?
  8. #328
    Cruz control went out today. What to do? Or what to check for?
  9. #329
    It came back. Thanks for the help -____-'
  10. #330
    This is the general question thread. There is a sub-forum elsewhere that is dedicated to car problems.
  11. #331
    Re: General 8G Question Thread
    Quote Originally Posted by M-Rod View Post
    X2
    '95 Kawasaki ZX9R
  12. #332
    anybody know if the 04 4g64 valves are the same size on both sides?
    8th Gen Rox
    http://mynccruizer.tumblr.com/
    OBX Long Header 12" Visonik Subwoofers x2
    K&N Typhoon SRI 15" L7 Kicker Solo Baric
    3" Muffler
  13. #333
    The exhaust valves are never the same as intake.
  14. #334
    06-18-2011
    chicago suburbs, IL
    600
    Any recommendations on how to remove the sway bar link nuts? Mine keep spinning with the bolts
    Just because something is old, doesn't mean you throw it away
    Geordi La Forge
  15. #335
    Just pop of the link itself, then cut them out
  16. #336
    12-13-2010
    Brooklyn, Maryland
    4,638
    I've never changed end links, but aren't they like ball joints, where theres a cutout for an Allen key to go into the bolt to hold it still while you use a wrench to take the nut off? It's slower than cutting it out, but if you don't have power tools, it may be your only option.
    -Greg
  17. #337
    05-14-2010
    Coachella, CA
    5,954
    Should have an allen socket in it however I have seen some without them (aftermarket reman). Good thing we had an impact to bust the off real quick.
  18. #338
    06-18-2011
    chicago suburbs, IL
    600
    wow, I just rounded the allen socket, my highschool auto shop teacher is reccomending nearly cutting the nut in half with a dremel, insert a flat head screw driver into the slot to hold it in place and take it off with a wrench
    I'm not sure if I should do this
  19. #339
    My allen ends on my end links rounded out when did mine a few years back also. At that point I only had a dremel but was able to use the cutting wheel to cut through the nut at the ends of the links.
  20. #340
    Attempting to actually unbolt the endlinks isn't even a consideration anymore. If they're stock, they need cutting off.
