Thread: Galant306m's turbo build
Page 58 of 65 FirstFirst ... 848545556575859606162 ... LastLast
Showing results 1,141 to 1,160 of 1287
  1. #1141
    TGC Regular bgood12's Avatar
    07-17-2009
    From Dallas, Texas in Topeka KS
    554
    Good luck man with the turbo. it sducks cause on one hand you want the a new turbo from mitsu but that like 2 grand and on other you are like wait I should be able to have this rebuilt no problem but people think they know what they are doing and might not. As a last resort try calling road race engineering and ask who they use to rebuild their turbos.
    Sent from my BlackBerry 9360 using Tapatalk
  2. #1142
    08-13-2008
    Waterbury, CT
    3,331
    Precision always wants to kill you and get you to pay for a rebuild and new parts. They say oil contamination, but did they say what it is like bearing material or anything? Also, idk if you already have this but it may help to put a restrictor in the feed line from the oil filter housing as ball bearing turbos require less oil pressure, or just feed from the head as every dsm with a BB turbo I know feeds from the head and my best friend has run an FP3052 from the head for around 4 years and now runs a Precision 6776 the same way with no issues for thousands of miles.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  3. #1143
    07-17-2009
    554
    True on the feed from head that 4g63 performance book says for ball bearings clean oil is especially important and to get max life use also an in line oil filter in the feed into the turbo as extra help for it.
  4. #1144
    Yea im going back to feeding from the head i had 0 issues when i was, never got the turbo out i have not had a ounce of time for the car but i did buy a bike which is paid for and not picked up lol
    I really want to get this car up and running before my friend and i move out but with 70-80 hr weeks at work its really hard.
    Plans for it atm
    New rod bearings
    Fix turbo
    found a really rare item for the car that im going to buy
    custom sway bars im going to make at work and have powder coated
    custom aluminum rear control arms
    custom aluminum solid motor mounts
    lsd for the trans (winter)
    custom aluminum solid sub frame bushings
    TAKE TO ROAD AMERICA!
    1996 galant s
  5. #1145
    Time to make this thread active again, everything set in place to get this thing running, crower 288/288 cams will be ordered this week
    turbo NEEDS RUBILD STILL never actually got it done its gonna happen no for sure
    upgrading my rod bearings and possible going to forge the shit out of my engine
    4g63 oil block is a must to get the proper oiling to the turbo
    this car will be on the road or in a scrap yard in 2013
    1996 galant s
  6. #1146
    lol lets hope for it being on the road. weird about the turbo. i used a sandwich adapter with a restricted fitting on the turbo and never had a problem.
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  7. #1147
    Turbo is on its way to tampa as we speak for the rebuild, also bought a new oil pressure gauge and a oil filter spacer block. Going to buy rod bearings tonight.
    1996 galant s
  8. #1148
    w00t!
    Quote Originally Posted by Galant306m View Post
    Make sure you use a restrictor fitting on your turbo inlet
  9. #1149
    Yea those damn precision turbos are picky about their oil pressure
  10. #1150
    Should have the turbo back by the end of the week which means the car should be running by next weekend give or take a few days depending on what parts i will need to get it running again.
    1996 galant s
  11. #1151
    You and Rob should both come dyno with me.
  12. #1152
    Pft im not driving my car that far lol and i dont have tahoe to tow it there lol. Not to mention I doubt that dyno would like 3 400+ whp cars dynoing right in a row HAHA
    1996 galant s
  13. #1153
    Excuses excuses. I watched 25 cars dyno on Saturday and most of them put down over 400whp. You should come do the same. I know I will so long as the tires don't fricken spin...
  14. #1154
    My car would be nowhere near 400 whp
  15. #1155
    So? Mine will be closer to 5 so it'll make up for it.
  16. #1156
    ^LOL! thats awesome
  17. #1157
    Quote Originally Posted by Silvertune View Post
    You should offer a new service with your car "free dyno roller polishing"! :)
    1996 galant s
  18. #1158
  19. #1159
  20. #1160
    I can vouch for how well it works!
