Originally Posted by
mko
I just watched the videos and i have a few suggestions.
- what injectors are you running? if you have bigger injectors how do you compensate for them.
- I'd assume you're using 74 crank trigger plate, right? IDK if it matters using 74 distributor with it.
- Double check timing marks, I hope you spun the engine by hand after installing the timing belt.
- What psi is your AFPR set to with the vac line crimped?
- Make sure the firing order at the distributor is correct.
- Make sure the injector plugs are at the correct spots and that you get +12V on all 6 outgoing wires of the resistor box.
- Connect the MAF to the throttle body, just for troubleshooting purposes, to eliminate any possible post MAS leaks causing rich conditions.
