Im trying to find a Outlander manifold, were there any 2003 Mivec Outlander's? If you know the answer just answer with a YES or NO, i know all the other necessary info.
'91 Kawasaki ZX7 (SOLD)
'95 Kawasaki ZX9R
4g64T 5spd
idk if this is the rite place to ask but i have a 2000 g a/t and i did a tranny swap with a 03 a/t trans but im still getting codes and it shifts rough from 1st to 2nd and speedo isnt working i put a 2000 speed sensor on it. i was wondering if you guys can help me figure out prob
for those of us that have done engine swaps, anyone know the rear lifting point for the 6g7 engines? the front point is obvious, but I can't figure out which one of the brackets on the rear head for this is
also I have seen occasion pictures of this, is it possible to use a few super strong straps under the engine attached to the engine hoist to lift the engine?
The lifting bracket in back is in the opposite corner of the front. Some engines got a tab on the steel bracket behind the upper PS bracket.
Straps are a bad idea with the engine because the sharp ends all over it cut into them. However I have lifted all my engines with two-loop chain harness.
noted, although the heads are off the block right now (stripped down to the short block) and I know ahead of time the block is done (cracked), so any thoughts of hoisting the short block without putting the heads back on?
Cruz control went out today. What to do? Or what to check for?
It came back. Thanks for the help -____-'
This is the general question thread. There is a sub-forum elsewhere that is dedicated to car problems.
'95 Kawasaki ZX9R
anybody know if the 04 4g64 valves are the same size on both sides?
8th Gen Rox
http://mynccruizer.tumblr.com/
OBX Long Header 12" Visonik Subwoofers x2
K&N Typhoon SRI 15" L7 Kicker Solo Baric
3" Muffler
Any recommendations on how to remove the sway bar link nuts? Mine keep spinning with the bolts
Just because something is old, doesn't mean you throw it away
Geordi La Forge
I've never changed end links, but aren't they like ball joints, where theres a cutout for an Allen key to go into the bolt to hold it still while you use a wrench to take the nut off? It's slower than cutting it out, but if you don't have power tools, it may be your only option.
-Greg
Should have an allen socket in it however I have seen some without them (aftermarket reman). Good thing we had an impact to bust the off real quick.
wow, I just rounded the allen socket, my highschool auto shop teacher is reccomending nearly cutting the nut in half with a dremel, insert a flat head screw driver into the slot to hold it in place and take it off with a wrench
I'm not sure if I should do this
My allen ends on my end links rounded out when did mine a few years back also. At that point I only had a dremel but was able to use the cutting wheel to cut through the nut at the ends of the links.
Attempting to actually unbolt the endlinks isn't even a consideration anymore. If they're stock, they need cutting off.
