I would think not, since typically the rim size changes, but the over all diameter stays pretty much the same. I'm assuming that you bought the Tein springs, and in which case you still have the factory style strut which will limit how tall a wheel and tire combo you can use. With a coil-over set up I imagine you could get a taller wheel and tire with a larger diameter to get you off the ground more, but then you throw off your speedometer and cruise, and I dunno what other problems it may cause. I'm not sure if you can tinker with the computer to adjust it for tire size or not. Perhaps someone else can answer that. I know I've seen where others here have put 19s and 20s on their G, but I don't know exactly what all they had to do to get them on. Search around a bit and you should be able to find their posts. Hope this helps a little.
Later...
