Welp this is new.
Wood prototype used to figure out measurements angles and clearance isuses haha. its easy to work with
and an hr later on me cad program
I believe that it is. I blew that fuse once and drove the car like normal, until the battery drained. After that, I realized what had happened.
U planning on getting a custom one made??
'91 Kawasaki ZX7 (SOLD)
'95 Kawasaki ZX9R
4" thick won't hit the grill on the bumper?? No need to cut it at that thickness??
'95 Kawasaki ZX9R
Can't find one with dimensions close to what u need ??
Sent from my Xoom using Tapatalk 2
'95 Kawasaki ZX9R
That wouldn't fill up the whole front opening I'm assuming. U posted your core measurements.
But didn't post the overall dimensions of what u r needing.
'95 Kawasaki ZX9R
'95 Kawasaki ZX9R
ETS will make a customer intercooler for about the same amount of money as a production unit. I've already checked. So custom for such a project is the best way to go
Nice build, very EVOish. I like it. I like to see newer galant's with more then just looks.
91 Galant VR4 -Samara- #550/2000
Lookin really good.
4G64/63T
AEM EMS
With regard to the fuse. It's a little different depending on your wiring layout for he power system. If you run the alternator wire from the alternator back to the battery in the trunk, then another wire from the battery to a power block under the hood, then you can just do a 150amp breaker on the wire from battery to power block. If your running a wire from the alternator to a power block, that's gotta get fused or have a breaker. The idea is to prevent an alternator surge from damaging stuff.
4G64/63T
AEM EMS
Yeah you likely won't find a 120amp breaker. Going up to 150 isn't going to hurt anything. I've been running 150's for almost 4 years, XD_01 is running a 150 too I believe, so is Spdracr, no issues.
4G64/63T
AEM EMS
