Thread: General 8G Question Thread
Page 18 of 33 FirstFirst ... 814151617181920212228 ... LastLast
Showing results 341 to 360 of 650
  1. #341
    Re: General 8G Question Thread
    Wiggle the endlink until it breaks off the ball end. If that doesn't work then hit the middle of the link with a hammer and it will pop off. Then use a vise grip to hold the ball and use a socket on the other side and unbolt it.
    Hope this makes sense.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  2. #342
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Someone is interested in my a/t tranny and is asking about the trans ecu?? don't really know if it exist or where is it or if I can get it out of the g without any adverse effect
    4g64T 5spd
  3. #343
    Etacs ecu, and its under err to the right or behind the fuse box inside the dash. There is alot more stuff that goes through that ecu then just transmission stuff iirc
  4. #344
    05-14-2010
    Coachella, CA
    5,954
    Would it be possible to use the dual fan setup on newer 8G's
    On one that came with the single fan?
    Sent from my DROIDX using Tapatalk 2
  5. #345
    Should be no problem. It should be a fan connector on the main fan and clips to hold the wire
  6. #346
    05-14-2010
    Coachella, CA
    5,954
    My concern is the single fan being variable speed and I imagine
    The aux /condenser fan being single speed.
  7. #347
    Should be no problem. The EU spec Gs 97-00 without AC has only 1 fan and the ones with AC got two. After 00 and to 03 models all came with both fans. And all of the models had the same unit mounted on the main fan and with a connector so u could mount another fan incase they wanted AC.
    It should be the same radiator/fans/AC units that are one EU and JDM Gs. The only difference between em is a little higher displacement, looks on the outside/inside and a relocated battery.
  8. #348
    07-02-2011
    South Florida, by the beach
    1,076
    For everyone who has done the 5-speed swap on the V6, how did you get the 2 bolts off the bracket on the passenger's side that holds the axle. I was able to remove one bolt but the other one is ridiculous to get loose because there is no room. I started to remove part of the exhaust but then it got too dark outside.
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  9. #349
    TGC Regular Guzm4n's Avatar
    02-02-2011
    Des Moines, IA
    736
    I used a wrench for the other one iirc
  10. #350
    You can do both with a 3/8 ratchet and a shallow-well socket. Wrench goes above the axle but parallel with it, then you can use the axle as a grabbing point and hand crunch the thing. Takes a good bit of strength the first time around.
  11. #351
    07-02-2011
    1,076
    Thanks!
    00 Eclipse RS MT
  12. #352
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    Who has Diamante TB? I need to know what's the inside diameter of it. I know its supposed to be 65mm , but i really wanna know the exact size. Im thinking of getting a throttle plate off one and sending my TB off to the machine shop to have it bored out.
    Build Thread
  13. #353
    Hey guys, so I have everything wire up, just waiting for my harness to use the evo ecu, just for shits and giggles I plugged the stock 99 auto ecu back into the car and tried to fire it up to see if it would start, lights would turn on the dashboard, but the car won't crank at all, any suggestions? I have evo injectors with the resistor pack wired in, I didn't touch the wiring the runs to the starter or anything of that nature. Any suggestions? battery is brand new. all the wires on the starter are tight, the relay/solenoid thingy for the starter in the fuse box makes a clicking noise when I turn the key, goes click click, but no starting, I'm getting stumped guys.
  14. #354
    09-20-2007
    Sea Isle city, NJ
    4,098
    Maybe weak ground?
    See if you get 12V at the main starter terminal and then 12V at the solenoid when you turn the key to starter position.
    Build Thread
  15. #355
    Pull the rail out and put it on a paper towel and crank it. See that the injectors are opening.
  16. #356
    that's the thing, the car won't crank at all whatsoever.
  17. #357
    I'm assuming a car won't run without a starter relay correct?
    both the MT and AT starter relay slots on my car are completely empty... I haven't touched them ever, car always started and ran fine, I guess it's time to see if putting one in will make a difference.
  18. #358
    Quote Originally Posted by greddy View Post
    Really cars don't need starters to run. Only to start. Starter can be removed and car can be started by hand if needed. I suspect someone bypassed the starter relay? Wouldn't make much sense to me why anyone would though. I would test those leads to see where they go before putting anything in them that may cause a short.
    Sent from my Galaxy Nexus using Tapatalk 2
  19. #359
    by run I meant start. car has been in my family since brand new, only thing I can think of is one of my friends playing a cruel joke and taking the relay out while I wans't looking.
  20. #360
    02-02-2011
    Des Moines, IA
    736
    Anybody know the size of the PCV hose?
