Thread: MKO's AWD/Turbo/DOHC/5 Speed Project
Page 40 of 53 FirstFirst ... 3036373839404142434450 ... LastLast
Showing results 781 to 800 of 1043
  1. #781
    It looks much better than brand new, built for the long haul love the kevlar and all the other goodies.
    7g Dirt Racer- 95 Galant- 4g64,5speed swap, external coil, dohc swap, 60mm t.b., b.s., a.c., p.s. delete, battery relocate.
    7g Street- 94 Galant GS- 2.0 4g63t, awd conversion, auto swap, 98 gsx ecu, fmic, maft, bs delete.
    3g 00 eclipse gt 3.0 at
  2. #782
    I am loving this build. I've learned a lot about 7g just from reading this build. Keep up the good work.
  3. #783
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    Build Thread
  4. #784
    Aww snap!
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  5. #785
    nice work, you gonna be running stock motor mounts?
  6. #786
    09-20-2007
    Sea Isle city, NJ
    4,098
    Well they are filled with liquid urethane with 80A hardner. I hope it isnt nearly as bad as the Prothane inserts. I really hate the vibration from them, plus im trying to have a comfortable DD thats why i didnt go with coilovers too.
    Build Thread
  7. #787
    gotcha, one thing that will fix the idle vibration for the prothanes is bumping the idle 1-200 rpm, makes them almost completely stop vibrating your dash apart
  8. #788
    09-20-2007
    Sea Isle city, NJ
    4,098
    Did that long ago, the thing vibrates while i drive too. I really am sick of it. I saw a picture of prothane mounts with holes drilled in them.
    Build Thread
  9. #789
    09-20-2007
    Sea Isle city, NJ
    4,098
    I just found out my shifter cables dont work with the AWD trans.The cable, that moves back and forth for going into gears, isnt doing its job somehow. Im gonna look into it tomorrow.
    Build Thread
  10. #790
    09-20-2007
    Sea Isle city, NJ
    4,098
    My red G inhaled some water and it was down this morning, just to find out one of my ignition coils was arcing making the engine sputter. I got it fixed in a second.
    I installed the entire drivetrain on the green; just came back from installing the drive shaft which was a complete PITA. Ill be working on the harness tomorrow - shorting wires and tucking them away; Should be trying to start the car sometime next week and then start on the exhaust.
    Build Thread
  11. #791
    09-20-2007
    Sea Isle city, NJ
    4,098
    Can you tell I had the harness installed?! She is in and she is shorter and partially tuck.
    I'll be installing the fuel pump and ecu tomorrow and hopefully she will start soon.
    Build Thread
  12. #792
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    Glad to see you're making progress. The harness looks good.
    Why do you have an AN fitting on your exhaust manifold? Also, why so many clashing colors in the engine bay? You spent all that time making the interior so nice and it looks like an ADD painter went to town under the hood.
    One comment on function you may not want either but putting a 90 elbow at the radiator entrance will seriously harm water flow. I'd strongly encourage changing that back to a straight inlet or a 45 deg. inlet.
  13. #793
    How come no one else wants to try speed dnesity with me??
    Looking good btw
    1996 galant s
  14. #794
    09-06-2008
    533
    Quote Originally Posted by Galant306m View Post
    I've been runing SD since I built my car. DOHCStunnr was running in on his 7G too until he sold it and the new owner totaled it.
  15. #795
    09-20-2007
    Sea Isle city, NJ
    4,098
    Quote Originally Posted by eclipsh View Post
    You talk about my red heater hoses dont you? yeah they stand out. I just wanted to have some fun man - dull looking car on the outside and shiny stuff under the hood.
    I'll consider your advice on the rad fitting.
    Build Thread
  16. #796
    09-06-2008
    533
    Nah, more the combination of red, purple, black and blue. Just too much going on. In my opinion a single accent color works better.
    Thanks for considering my advice on the radiator. I am still curious as to why you have an AN fitting coming off the exhaust manifold. What is it for? Depending on what alloy it is the aluminum might melt once your manifold is hot.
    Edit: It was just sitting there in the photo and not actually attached, wasn't it? It looks like that is the fitting for your radiator. I'm a dork.
  17. #797
    09-20-2007
    Sea Isle city, NJ
    4,098
    Yeah thats the rad fitting.
    Once i put the t-belt covers the blue will be gone, and I've had the red hoses ready for the red G, but im a bit tight on funds so they are going here
    Build Thread
  18. #798
    12-17-2004
    Louisville, KY
    4,327
    Get it done. I'm ready to see this beast throw down.
  19. #799
    12-17-2004
    Louisville, KY
    4,327
  20. #800
    09-20-2007
    Sea Isle city, NJ
    4,098
    What do you think - 225/55/16 or 225/50/16?
    Just found these pics of GST wheels with 225/55/16. Purpose is to have a comfortable and yet good gripping DD.
    Build Thread
