Thread: Reverse light / back up light always on
Showing results 1 to 9 of 9
    NEWBIE fernalob's Avatar
    06-14-2012
    Rodriguez, Rizal, PH
    13
    hi TGC,
    is it easy/safe to DIY-replace a faulty reverse/backup light switch? its always ON and (i think) it's somehow consuming my battery even the car is off..
    i temporarily removed its fuse to shut it off, it's just hard when backing up at night..
    thank you..
    05-14-2010
    Coachella, CA
    5,954
    IIRC removing are the fuse blowing will cause it to go into limp mode. Correct me if im wrong guys.
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    Does your car have a manual transmission?
    If yes its on top of the trans, and its very easy to replace.
    Build Thread
    06-14-2012
    13
    ^ owww .. but so far it didn't had any trouble aside from tottaly shutting off the back up light..
    7G
    1996 Galant
    2.0 4 cylinder (4G63 SOHC) (E55A)
    06-14-2012
    13
    saw it! it has a 2wire connector and on top of the trans.. thanks for the picture mko! yep its manual :)
    7G
    1996 Galant
    Is the switch in the same location for an automatic transmission? I'm trying to locate where the wire is ran from so I can wire in a wireless transmitter for a backup camera
    05-14-2010
    Coachella, CA
    5,954
    Quote Originally Posted by JimboJizm View Post
    On the autos it's different. Its on the main harnesses. Rather than messing with that, get it from the tail light in the trunk and route it in through the panels, not as hard as it seems.
    Well I'm trying to not have to run a wire from the trunk to the front, it defeats the purpose of the backup camera wireless transmitter/receiver, I want to find out where it is ran from the reverse switch
    05-14-2010
    Coachella, CA
    5,954
    Not really since its the power you are running and not the video. Not only that tapping into the light is way easier than running the video wire from the trunk lid.
