Thread: Cylinder head bolt.... Mb991654
Showing results 1 to 5 of 5
    ZiplokeR
    Hi folks,
    Can a 13mm socket remove these head bolts? The 13mm fits good but I don't wanna strip the bolt.
    If not, Does anyone have a mb991654 for sale?
    Tks...
    Sent from my SGH-T889 using Tapatalk 2
    It's a 12mm 12 point socket right?
    I think this should work?
    http://www.ebay.com/itm/Proto-Profes...067def&vxp=mtr
    If not, let me know, I can check at my local Mitsubishi dealer to see if they have the Part# for sale.
    07-02-2011
    South Florida, by the beach
    1,076
    I read online to use a 10mm allen wrench socket, try it and see if it works.
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
    05-14-2010
    Coachella, CA
    5,954
    Use a 12 point. Honda rod bolts are like that also.
    ZiplokeR
    Yup.. Thanks. I picked up a 12 point socket set and baaamm, cylinder head is out. U learn something new every day.
    Now I have problems figuring out why I had no compression on one of the cylinders,
    https://www.thegalantcenter.org/showthread.php?t=53081
