Umm..get ammonia spray your windows with it and let it bake in the sun for 3-4 hours...the longer you let it bake in the sun the easier it will be to get off.
what would the best way to remove crappy tint!
Thanks
Marcin P.
ANSA Exhaust
Apex Springs
KYB AGX struts all the way around
(slowly working on more things)
Speed doesnt need beauty ~ Me
and then if there is any glue residue, get a very fine steel wool and scrub it out using some windex and polish with a terry cloth towel. as for the rear window, be very careful, u don't want to damage anything. chances are u'll damage ur defroster lines...its gonna be hard to not damage them
just make sure u dont scratch the glass with the steel wool
actually really fine steel wool will scratch ur glass...a bad scratch no? actually its kinda like wet sanding....it will make ur glass shinier my sanding away some of the microscopic scratches on itOriginally Posted by MitsuMan
thanks for the tips. hopefully i won't f-up the defrost lines.
