http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=38634
found this on also.
thanks peps
dont know much about these just see them on most of the g rides up in here. what is the difference between cold air and regular air intake? And what gains will I see with the above items.
found this on also.
thanks peps
quick note about the injen. the injen is the first gen intake for the 3g eclipse. it will fit your galant. its a lil bit louder than then newer injen intakes. if i were to bid on it, i'd first ask the seller of a close up. you see where that silicon hose is. around that area would be where the bolts for the battery tie down would be. and on the older injen's thats where the pipe would rub against the bolt and eventually wear a hole into it. so yea, i'd watch out for that.
