A good drill press and some careful attention to detail and it works just fine. For the turbo Volvo's we drill out the oil feed for the turbo and tap the block regularly. Also if a factory style drain is desired the block has to be drilled yet again.
Obviously being careful and using the right tools makes all the difference.
