according to tein's website 1.7 in the front and 1.3 in the rear
OK first I ahve a quick question on the tein springs in a magazine it says that they are 1.6 front and 0.9 in the back for the 4 cyl. Everyone is saying that it's 1.8 front and 1.2 back. Who's correct? Another question is, Right now I ahve a heavy system in the back. If I were to install TEIN spring in the back would the sag as much as the factory or a lot less? I want to have the front a bit lower than the back. Please get back to me asap. thx PETE
one question out of the way. how about the sag?
Unless your system ways over 500lbs respectively, you should see little to no sag at all. The system could cause around 0.1 to 0.3 lower then what is said, but that is still above what the front will drop so it's all good.
thx I think I'll go woth the eibach springs all around with the gr2's I'll elt you guys know how it came out
