http://www.ebay.com/itm/Suspension-C...0cc656&vxp=mtr
this thing? there is only the 2 bolts iirc, one for the adjustment and one on the ball joint...the hardest part I had with it was the adjustment bolt was rusted solid into the bushing, broke the bolt head right off when I tried to break it loose (no pun intended)...had to cut the whole damn thing out! if your luck is like mine then it's a pain in the ass, if you're lucky and it comes loose easily then its not hard at all
