Originally Posted by
Silvertune
What do you need the evo ECU for?
I do have an 00 eclipse GS wiring harness if you ever find yourself wanting to start over. It's mostly complete, idiot cut the injectors, a coil pack and the ac pigtail off before I got to it but I picked up the pigtails at least. Nothing that wouldn't be peanuts compared to your current situation.
If the duty cycle doesn't ramp up significantly as it starts to boost than you have either a bad ECU or more likely something feeding the ECU is bad. I would log the MAP sensor, get the IAT working at log that also. If the ROM function has been confirmed than those are your final variables.
