Originally Posted by
6G72gearhead
Before you continue to replace parts or replace the PCM you need to test for voltage and do voltage drop tests. First you need to check for voltage drop from the positive battery terminal to the alternator output.
You can get wires to resistance test fine, but they can still be bad as the resistance goes up as current passes through the wire. When you voltage drop test wires you are trying to see if any voltage is trying to bypass the wire through your meter.
Its not totally impossible to have 2 bad alternators, unlikely, but not impossible.
Get ahold of a wiring diagram and test to see how much voltage is getting sent to the regulator to run the stator, that could easily be the cause of the issue.
