-Greg
You guys think I could fit a bumper in the g?
It was six years ago, so I can't remember exactly how it was in there. I just remember that I did it. I can't remember if I moved the passenger seat all the way up and leaned forward, or if I moved the passenger seat all the way back and reclined it.
Probably have to stick one end out a window I'm sure its possible
Looks like he went passenger front to the back seat...
Yes I've done it a few times too. Passenger front seat pulled all the way forward and then reclined all the way back. Keep the back door closed and slide the bumper the way it is in the picture through the front door and lay the other end on the floor in the front. Doors close without any twisting of the bumper required.
Juicejax - get a dremel and make the grill yourself! Mine is battery powered so it took a little longer (2 or 3 recharges later) but with like 2 hours you'd be done on a wire)
Get a saw blade attachment, notch it like this:
Twist the pieces out with ease, then start grinding them down with a sanding whatever...either a wheel like a grinder uses or they have little sandpaper rolls (I used both, wheel for major chunks and roll to smooth out)
That's when I had to get ready for my date but it's super easy, great way to get some exp with the tools and methods
Hey im going to move the battery to the trunk. What gauge wire would yall recomend?
2001 Galant 2.4 USDMOld ones
2X BMW E34 Blaaackkkk
Isuzu Trooper mountain spec
I've always been told minimum 4 guage and to use audio power wire because its more flexible.
