Gold ftw!
Sent from my SAMSUNG-SM-G900A using Tapatalk
Did my wheel will take good pictures when i install with lug nuts and fix my camber.
Sent from my SM-G386T using Tapatalk
Gold ftw!
Thanks man! I debated onon doing black for that exact reason, but I'm glad I didn't. I already have black mirrors and a rear visor that's black..and I just installed weathertech window visors. So a black lip sittin on the truck I feel now would break the car up too much from the silver if that makes sense.
Like that evo wheel, nice addition to your interior
Wheels came out looking great btw boosting90
Right as rain. No problems with a +40 offset. (or +35 for that matter)
Thanks M-Rod. Went today and stared pulling parts off my friends Stratus. Unfortunately he sold his wheels and just set the car on the ground in the weeds and his bobcat died so we couldn't lift the car to get wheels on it and get it in his garage to put it on his lift. Managed to get everything but the tranny, and intermediate axle.
http://
Got these at the junk yard a couple weeks ago and cleaned them up and repainted them. Caulked the inside to hopefully keep the water out so they don't rust out like the set on my car now.
http://
And lastly, I finally found the right TB. Now if I only knew of anyone who did port work on these and intake manifolds
http://![]()
New bumper and lip
Sent from my ALCATEL ONE TOUCH 4037T using Tapatalk
MODS
5 speed swap
Eibach Pro Kit on GR2 Struts
Cold Air Intake
Outlander Intake Manifold
6G72 V6 Throttle Body
6G72 V6 Fuel Pump
Axle Back Exhaust (ebay)
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Prothane Motor Mount Inserts
MODS
5 speed swap
Cold Air Intake
6G72 V6 Fuel Pump
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Nice update. I like the idea of sealing the rear strut mounts. I'll need to look into something like that before I swap out my coilovers back to a strut/spring setup on my Eclipse for Winter soon and that may be the ticket.
Also, Justin does porting and rebuilding of throttle bodies, as well as porting manifolds. We actually performed a ported heads swap on another out of state visitor's 3.8-swapped car this past Saturday. I can talk to him and get back to you about a built throttle body if you would like.
Yea, that would be great if you could M-Rod. And congrats to him for winning 1st again. I so wish I could've come this year but life had different plans. Hopefully next year. Also, I read that you and Justin run Motul 300 tranny oil but is that only because you guys run LSDs or would that be a good one to run year round on a daily. It's between this and the "Gray Mix". It's the last thing I think I need to order to do my swap.
A quick diy on the cluster back light, looks 5 years younger now! :)![]()
