1991 Jeep Comanche (SOLD)
2002 Honda Accord EX (DAILY)
1998 Eclipse GST (PROJECT)
Fair enough
These arrived yesterday
'91 Kawasaki ZX7 (SOLD)
'95 Kawasaki ZX9R
Made this for a customer. Rear turbo dump
Pipe. No more restriction here. Lol and a flash y pipe
In progress shot.
Scored found my tranny. 125$$$
Sent from my SM-G386T using Tapatalk
Some stainless bolts for freshness.![]()
^^ Lookin good Trotty!!
Update on the check engine light, it does have something to do with the exhaust. He said it could be a simple leak or it could have something to do with a charcoal canister?? Also said there is no harm done to the car, it is just a little less efficient.
Finally I'm 5 speed swapped. Got the Prothane mounts on the motor and front control arm. Need to figure out how to get the axles out because they are fused into the hubs, wire the the sensors in, and put in the rear Prothanes. Can't wait.
When it happened to me I got new axles and spindles from the yard.
I tried it all including heat with a torch.
Buy new knuckles from the Mitsubishi dealership, they are cheap cheap cheap! (Seriously! When I had to replace an axle, the replacement knuckle was MUCh cheaper than in the boneyards). Then buy new hubs and axles.
If that happens again, buy the spindles/knuckles from the Mitsubishi dealership.
Horrible pictures be damned, but I had to post this anyways!
^^^ You have two 3 cylinder galants?:D
They look clean AF!
