Originally Posted by
SolerSPL
Typically with aftermarket radios, if the wires were not properly crimped or soldered they'll come apart. My suggestion is pull the headunit (takes 2 seconds with these cars). If you used a wiring harness with your headunit then remove that and check all the wires to make sure theyre all attached. If they're crimped or soldered, give the headunit harness and galant harness adapter wires a tug individually to ensure they are actually attached.
Its unlikely that the factory speaker wire got frayed so thats your best bet.
