Have you seen KW's for an 8g? The KW V2 for the Fit were almost exactly the same length as the OE Showa dampers. And the KW 1.5-2" drop, wouldn't that include the shorter damper? I can't imagine them advertising a certain drop range and actually getting much more. Additionally, KW are generally quite soft, often times with progressive springs...that is quite a bad thing if you want to be very low.
