NEWBIE
Welcome to TGC! Take it from someone who has been rear ended twice and is on his 3rd 8g now: that is not worth to fix. You can find a good shell-worthy Galant if you look hard 500-1000, a good running one under 3K any day, with less mileage. Transplant over anything if you need, save the parts for spare, or even sell them for recovery. The idle / bogging issue sounds likely the IAC is going.
NEWBIE
Thanks my friend, I will look into a replacement IAC valve in that case! Cheers!
