do you have a 94 GS?
Anyone know if this will work? http://search.ebay.com/search/search.dll?c...y=galant+engine
Just wondering
when is we gon be free????
The "GS" ecu is for the 4g64 DOHC...which setup differently from the SOHC. So if you are planning to use it with a SOHC 64...it ain't gonna run.
Yah, GS 4g64 uses DIS instead of a distributor...
and ISC instead of IAC i think also
I use DIS instead of a distrbuter =D
A GS ECU I *think* has conectors more like the 1g. I believe this topic came up on another group, and if thats the case even if you wanted to use it for a swap youd have to geta new harness and bla bla bla..
Why do you want it anyway?
Rob
rIp 97 Galant
starting over.
90 Talon
I wasn't going to get it, I would destroy my car. I was just wondering if someone could use it b/c i saw that you (jip) are using a 2g ecu and thought that maybe someone could use it. Oh well, I guess not.
Your beter off with a 2g ecu, (for ease of installation, I like the OBD1 features of the 1g, but you could always install DSMLINK in the 2g eprom ecu and have most of the same feauters with lots of extras), for a turbo setup just because of the knock control and larger injector support.
The GS my have a knock sensor I duno, but it still uses 270cc injectors which means more fidling with the AFC, etc..
Rob
rIp 97 Galant
starting over.
90 Talon
