stabilizer bar - MR468848 - $39.60
bracket, fr susp strut bar - MR468851 (for the left side) - $2.77
bracket, fr susp strut bar - MR468852 (for the right side) - $2.77
metric nuts - class 10.9 Hex Nut, M8-1.25 - 99085001 - $0.49 for two
washers - $0.13 for four
I don't have actual pictures of the install. But its a pretty straightforward install. The brackets mount to two of three bolts on your strut towers. Then the strut bar itself mounts to the brackets via the above metric nuts (Which you'll have to go to a hardware store, or look around the house to get). Simply install the washers, tighten the nuts and bolts and voila!
