it might fix the problem. for the cost of the tb cleaner, its worth a shot. it could be something else but try cleaning the tb first. its one of the more cheaper solutions.
my rpm keeps Fluctuating. would cleaning the throttle body fix the problem :?:
you have to replace the idle air control valve.
i cleaned the throttle but the problem is still there. in park the rpm goes up to 1500 in drive at the light or something it drops all the way down lie its about to cut off and then come back up to like 450. i'll try replacing the idle air control valve and see what happens.![]()
