mainly because your deciding when you should go to the next gear
that can put stress on the AT
If a AT overheats it can cause major internal damage
I can understand not using Over drive at times depending on road speed
The AT has been set up to change at certain speeds etc
Leaving it in 1 2 or 3 and pushing for that little extra power acellaration out can cause a lot of damage and $$$$$$$
I guess it does depend how long you leave it before you change up
I have the tiptronic AT and that has built in logic so i can't try and go from 5th to 2nd at high speed
Normal AT's dont have this logic so you can blow a AT very easily
Cheers Nick
