how about a 17x7 wheels with an offset of +42mm, riding on a 215 40 tires without a drop on the car? any suggestions on w/c tires would best fit the wheels? :?:
<div class='quotetop'>QUOTE(2True)</div><div class='quotemain'>I think peano was reffering to that setup as mounted on a 7g. Â*
A 235 will def fit a 7.5" wheel, but application wise it would never work unless you had some serious fender work done.</div>
i'm not too sure on that, you get 235s to go onto 8 inch wide wheels, just ask the goons at your local tire place
i'm a 205/40/17 on the pro kit about a 1" gap or so. the falken ziex512's grip mad!![]()
whats the lug nut size on a 7G? is it a 4x100 or 4x114.3?
not sure what the 4x thing means.... :oops:
iam thinking about getting these....
http://www.speedandstyle.com/index_main.htm
The REV BOOST style 17x7 with 215/40/17 tires...
um, it means "times" 4. as in you get 4 of them. 4X114.3 means you get 4 lugs that are 114.3Originally Posted by Sharky1116
...U N D E A D...
so the 114.3 is the lug size on 7g's?
<div class='quotetop'>QUOTE(Sharky1116)</div><div class='quotemain'>so the 114.3 is the lug size on 7g's?</div>
yes, that is the lug spacing
