Ptuning.com, here's the discount link...
www.ptuning.com/html/discount_code.cfm?clubid=ptgalantctr
How's it look??
Im looking for the lowest price. Thanks
How's it look??
Ya your car is what inspired me to get some springs. Did you install them yourself? And how long did it take?
BTW Clear corners.![]()
Thanks man, I'm pleased with it now that it settled in.
I did the install on my own, no help. Took about 4 hours, but I did take a few smoke/beer breaks!!
Here's the process...
1. Place the front of the car up on jack stands
2. Take off your rims/tires
3. Unbolt the 1/2" brake line bolts
4. Unbolt the 1/2" sway bar end link
5. Place floorjack under a arm and jack up just until the car starts raising off the jackstand, then lower a bit
6. Unbolt the two 15/16" strut bolts and remove (breaker bar is helpful)
8. Unbolt the 3/4" strut nut from on top of the strut housing in the engine bay
9. Lower the floorjack slowly
10. Remove srtrut/spring from wheelwell
Installation is the reverse of removal
This is really easy this way
You do NOT need to remove the three nuts holding the upper strut mount on
Got any pics of your clear corners? I thought about it, but wasn't sure how it would look on the black ride...
BTW, I didn't get any of the camber kits. Just had it aligned last Sunday, and all within spec, the guy said that the front was great, the rear was really close, but nothing to worry about. Learned from this board that some need it, others don't!!
Heres a pic of another members. Your going to have to get chrome bulbs. Since I dont have chrome bulbs yet mine kinda look dumb with just a long orange bulb.
Ya i ordered my springs last night, they should be here by tommorow or day after. Dammit now I have to save up for struts. And the worse part is that I want to get HIDs, but since the ban their probably going to become a hell of a lot more rare.
Anyways thanks for the tutorial ill use that along with my Chiltons guide, and Mitsu Service Manual. You can never be over prepared.![]()
which springs to u guys reccomend sprint or progress and how much of a drop for each
madspeed urs has dropped a lot now
Do you guys know where I can just get the front springs?
-MIKE.
<div class='quotetop'>QUOTE(clone2020)</div><div class='quotemain'>Do you guys know where I can just get the front springs?
-MIKE.</div>
best bet, is forums like this one and on ebay.
most if not all companies that sell springs for our cars sells them in sets of four
