Thread: HELP HELP HELP HELP
Showing results 1 to 14 of 14
    yoyo6999
    HELP HELP HELP HELP
    sethmo
    Only engine swap you should consider:
    -6bolt 4g63t from a 1990/91 turbo eclipse/talon/laser
    Manual swap isnt that hard. the engine swap is very time consuming. I wish I would have just turbo'ed the '64 and did a 5spd swap, it would have taken me half the time its taking me to do the '63t swap...
    BTW, your new rims look way better than your old ones
    and that pocket bike is pimp haha
    Experienced TGC Member
    01-10-2003
    BROOKLYN nYC
    1,570
    Seth I think your engine swap is takin so long cause its a 1g and it takes more "customizing" then dropping a 2g turbo in would.
    Rob
    rIp 97 Galant
    starting over.
    90 Talon
    08-01-2002
    North Bay...NorCal
    2,552
    Like the rims, hate the hood. It just makes me think of a pig! LOL all in all though, the ride is pimp! What color did you use to paint it? I was thinkin of goin blue myself
    sethmo
    Well if I didnt have to wait a month for my flywheel, and a week or so for every other part it would be done by now. Best advice I can give you is not to start your project till you have ALL your parts and know what you have to do before you start...
    You better be coming to Normal w/ that.
    First one: Red 88 - 245whp/312wtq - HIN: Nightshift - Chicago '07 WINNER
    Second one: Durban 88 - Buckskin - SHP - Auto - Sold to more capable hands
    Next one: White 84 flatty - t3/t4 - VELNAS - More to come
    "...Remember: Don't crush 'em, restore 'em!"
    yoyo6999
    Thanks
    [LIST]
    01-10-2003
    BROOKLYN nYC
    1,570
    if you already have an aftermarket hood...why would u be asking if anyone makes them??
    Rob
    rIp 97 Galant
    starting over.
    90 Talon
    yoyo6999
    hood
    [LIST]
    TWISTED II
    where did my post go? i offered to build you an engine if you supplied the manual from mitsu and all the parts/labor etc....
    redboy
    if u get any DOHC engine, turbo or not would u have to get the hood with a "bump" in it or no?
    sethmo
    You can cut the underside supports out of a non-hump hood and the DOHC should clear fine.
    Moosh
    I have a stock hood with no hump and the DOHC clears fine. So does Robs. No cutting needed.
    01-10-2003
    BROOKLYN nYC
    1,570
    You dont have to cut anything. It clears just fine. I supose if you want to run the upper timing belt cover you may have to cut. I have it I will check the clearance tomorow. I dont install the upper cover or the real DOHC lower cover. I have my stock sohc lower cover, but cut part of it out to fit it on without having to remove the stupid AC tensioner.
    Rob
    rIp 97 Galant
    starting over.
    90 Talon
