only one known is the mitsubishi FTO FWD tranny...
Does anyone kno if there is a tranny that can fit on a 6A13TT that is front wheel drive????
Fully Built 4G63
HKS 272
ported Dual Ball Bearing FP RED 84mm 25psi w/ external dump
there is a VRG Galant that comes with the 6a13 that is not turboed and is FWD
why wouldnt the stock 8G tranny bolt up? Isnt it oriented the same direction?
2.4 liters of whoop ass.
there is one, i cant remember what it is from though... search.
Transmission is the same code between the 4G64 and the 6A12, but the bellhousings are different. This has been discussed on Club3G, but their site is down right now.
Not to revive a super old thread but....
The transmission from the Mirage (1997-2001) 1.5L 4G15 and 1.8L 4G93 will fit direct bolt up only thing is if your using the 1.5 trans you need the Flywheel and clutch for a 1.8 to work.
Also you have to modify the front wastegate actuator as it sit right were the slave cylinder is.
You can also use the DOHC 4G93T's transmission that came in 1996+ Lancer GSR's for you UK and AU guys, these transmissions were 4WD but you can convert them to FWD and the slave cylinder is on the back side so no need for front wastegate modifing.
Drive, Dream, Drift.
Drift ALL DAY
I'm 300% sure they will work.
Because the Evo 4-8 engine fits in both the 8G Galant and 5G mirage (Mirage is Baby evo)
Because the 6A13TT is a direct bolt in in the 5G Mirage.
and last of all the 4G64 and auto/manual tranny are a direct drop in, in the 5G mirage
all being said the only thing I can see that wont work is maybe the axles.
im keeping on topic of the FWD
AWD its the same process for the AWD conversion on the Mirage.
I was just confiming transmissions to use to obtain FWD in tha galant with a 6A13
^ ohhhh
Drift ALL DAY
This is true and I had made a post of this a while back, saying that in MirageForums they do a lot of 6A13TT swaps using their stock 5-speed transmissions. I'm not sure how the automatic transmission will do under 287hp, most likely take a dump on your or something.
yea don't even bother with the autos
we have seen so many go on just 11PSI of boost on the 1.8 auto trans the 1.5 is worse.
To revive this thread because of recent questions...
Now the question is does the 4G Eclipse 6spd fit with the 6a13tt?
Seth I dont think half the people talking about this over on c3g or anywhere have any clue was to wtf their talking about. JDM Legnum guys talk about using EVO trannies in their cars, simple as that, the EVO bellhousing bolt pattern is the same as the 8g. So the real searching needs to be done over on the Aussie and UK VR4 boards.
4G64/63T
AEM EMS
