Thread: Manual Shift Nob on an Automatic!
Showing results 1 to 10 of 10
    thestig
    I figured out away to put a manual shift knob on a automatic transmission for the 8g's.
    I am not sure if it will work for 7g or 9g.
    TOOLS:
    -razor blade
    -manual shift knob(make sure it fits around the neck of the shifter: not too loose and not too tight.)
    -i didn't get a ball type shifter but a elongated manual shifter.
    STEP 1:
    remove the old bulky shifter. (i destroyed mine)
    STEP 2:
    cut the plastic stem to your desired height. (i chose to cut mine 1 inch above the top of the metal neck.)
    STEP 3:
    slip the manual shift knob over the neck.
    STEP 4:
    take for a drive. (to shift: simply press down on the entire knob and move back and forth to change gears)
    08-23-2004
    Chaska, Minnesota
    1,370
    pm you for pictures?! post them up and stop being lazy.
    yeah, post'em here
    01-24-2005
    DFW/Stillwater
    2,752
    u are an amazing driver
    Wow...thanks for the info!!
    Love,
    Matt
    08-04-2004
    Westchester NY
    1,332
    thats pretty cool... does it come off if u lift up on it tho?
    nice ash tray delete
    thestig
    yes if you pull up on it it will come off but i usually have a couple other laying around somewhere so i can change if i want too.
    thestig
    thanks yeah i like the ash tray delete too
    09-10-2003
    Charlotte, NC
    4,462
    your knob didnt have an allen screw to tighten on the sides? mine wont lift due to my side screw
Tags for this Thread
