Showing results 1 to 4 of 4
Thread: Mitsubishi Galant Fluid Specifications (6G-9G)
    1999-2003 (8g)
    A/C R134a - 1.44lbs (.7kg)
    A/T Fluid (Diamond SPIII) - 8.10 quarts (7.7 liters) (2.4 I4)
    A/T Fluid (Diamond SPIII) - 8.90 quarts (8.4 liters) (3.0 V6)
    Engine Coolant - 50/50 7.40 quarts (7.0 liters)
    Engine Oil - 4.32 quarts (4.1 liters)
    Gas Tank - 16.30 gallons (61.7 liters)
    Power Steering Fluid - 1.30 quarts (1.2 liters)
    Windshield Washer Fluid - 4.20 quarts (4.0 liters)
    1994 - 1998 (7G)
    A/C R134a - 1.48lbs (.7kg)
    A/T Fluid (Diamond SPIII) - 6.30 quarts (6.0 liters)
    Engine Oil - 4.52 quarts (4.3 liters)
    Gas Tank - 16.90 gallons (64.0 liters)
    Power Steering Fluid - 1.00 quarts (.9 liters)
    Manual Transmission Fluid (If applicable) - 2.10 quarts (2.0 liters)
    1987-1993 (6G)
    A/C R134a - 2.06lbs (.9kg)
    A/T Fluid (Diamond SPIII) - 6.40 quarts (6.1 liters) (FWD)
    A/T Fluid (Diamond SPIII) - 6.80 quarts (6.4 liters) (AWD)
    Differential Fluid API GL-5 (or higher), SAE 75W/85w - .74quarts (.7 liters)
    Engine Coolant - 50/50 7.60 quarts (7.2 liters)
    Engine Oil - 3.92 quarts (3.7 liters) (SOHC)
    Engine Oil - 4.42 quarts (4.3 liters) (DOHC)
    Gas Tank - 15.90 gallons (60.2 liters) (FWD)
    Gas Tank - 16.40 gallons (62.1 liters) (AWD)
    Power Steering Fluid - .95 quarts (.9 liters)
    Manual Transmission Fluid (If applicable) - 1.90 quarts (1.8 liters) (FWD)
    Manual Transmission Fluid (If applicable) - 2.10 quarts (2.3 liters) (AWD)
    Transfer Case Fluid - .63 quarts (.6 liters)
    Trans fluid - API GL-4 (or higher), SAE 75W-90, 75W, 85W (works in transfer case and transmission.
    2004 - Current (9G)
    A/C R134a - 1.40lbs (.6kg)
    A/T Fluid (Diamond SPIII) - 8.90 quarts (8.4 liters) (3.8 V6)
    Engine Coolant - Longlife or equivalent 50/50 8.50 quarts (8.0 liters) (2.4 I4)
    Engine Coolant - Longlife or equivalent 50/50 9.20 quarts (8.7 liters) (3.8 V6)
    Engine Oil - 4.52 quarts (4.1 liters) (2.4 I4)
    Engine Oil - 4.86 quarts (4.6 liters) (3.8 V6)
    Gas Tank - 17.70 gallons (67.0 liters)
