Thread: TCL and ANTI LOCK light
Showing results 1 to 7 of 7
    My cars TCL light and ANTI LOCK light just came on one night after work. They have yet to shut off. I have taken the car to AutoZone where they hooked it up to the hand held computer and the guy said it doesn't check for anti-lock or tcl. I wanted to know if anyone had any information on what it might be, and if it is a problem that I am still driving the car? Thanks.
    when turn on the "anti lock" and another light together, can be fail the alternator, check it!
    by own experience.
    __________________
    -Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
    -Mitsubishi Galant LS 1994 a/t [ SOLD ]
    7G must be different then. Charging system faults in the 8G are indicated by the "battery" and "brake" warning lights.
    '99 5-Speed GTZ: 6G74 Turbo 6764 9psi E85
    Do you own a 8G or a 7G?
    www.edelhausrottweilers.com
    Quote Originally Posted by jm0271 View Post
    7G
    is the Charging system, sheck your alternator :D
    __________________
    was this ur alternator that made the tcl and antilock light come on?
